Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
Use a spudger  to gently pry the ambient light sensor out of its recess on the front panel. Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
  • Use a spudger to gently pry the ambient light sensor out of its recess on the front panel.
  • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
Utiliza la punta de un spudger para levantar cuidadosamente el sensor de luz ambiental de su zócalo en el panel frontal.
Trata de colocar tu herramienta totalmente debajo del sensor para levantarlo del plástico claro debajo. Si haces palanca solo contra el cable, el sensor podría separarse del ensamblaje de cable y necesitará reemplazarse. Si estás reemplazando el ensamblaje de cable/sensor de todas formas, entonces no importa.
