Saltar al contenido principal
Samsung Galaxy Tab 4 10.1 Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Holandés
Paso 4
Samsung Galaxy Tab 4 10.1 Battery Replacement: paso 0, imagen 1 de 1
  • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
  • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
  • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
Insertar traducción aquí
