Saltar al contenido principal
Desmontaje Apple Watch Series 2
Inglés
Español
Traduciendo paso 17
Paso 17
Apple Watch Series 2 Teardown, Final Thoughts: paso 0, imagen 1 de 1
Final Thoughts
  • Apple Watch Series 2 Repairability Score: 6 out of 10 (10 is easiest to repair)
  • While not an industry standard, the watch band is easily removed and swapped out for a replacement.
  • Removing the screen is difficult, but not impossible—it's the first component out, and is connected with easy to use ZIF connectors.
  • Once you're inside, the battery is fairly easy to remove—if you have the proper tri-point Y000 driver.
  • While not proprietary, incredibly tiny tri-point screws are a repair hinderance.
  • Replacing any of the component cables requires microsoldering—but does not require removing the SiP as in the previous generation Apple Watch.
  • The fully encased S2 system makes board-level repairs impossible.
Insertar traducción aquí
