Saltar al contenido principal
TaoTronics TT-SK06 Front Grate and Metal Casing Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 2
Paso 2
TaoTronics TT-SK06  Front Grate and Metal Casing Replacement: paso 0, imagen 1 de 3 TaoTronics TT-SK06  Front Grate and Metal Casing Replacement: paso 0, imagen 2 de 3 TaoTronics TT-SK06  Front Grate and Metal Casing Replacement: paso 0, imagen 3 de 3
  • Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
  • Use caution when working with the metal spudger, as it can potentially damage your device.
Insertar traducción aquí
