Saltar al contenido principal
Dell Inspiron 15 3541 Hard Drive Replacement
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Dell Inspiron 15 3541 Hard Drive Replacement: paso 0, imagen 1 de 3 Dell Inspiron 15 3541 Hard Drive Replacement: paso 0, imagen 2 de 3 Dell Inspiron 15 3541 Hard Drive Replacement: paso 0, imagen 3 de 3
  • You can skip this step if you are not replacing the Hard Drive, but still need to remove it to replace a different part.
  • Remove the two screws (3mm long) using a PH0 screwdriver that are holding the hard drive into the mounting bracket.
  • Pull up on the black Mylar sheet and remove it from the existing hard drive, it has some adhesive, but will simply pull off with just a small amount of force.
Insertar traducción aquí
