Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 8
Pull the logic board slightly away from the rear facing camera. Do not try to remove the logic board just yet, as it is still connected by an antenna cable on the back. Flip the logic board toward the battery, as if you are turning the page in a book.
  • Pull the logic board slightly away from the rear facing camera.
  • Do not try to remove the logic board just yet, as it is still connected by an antenna cable on the back.
  • Flip the logic board toward the battery, as if you are turning the page in a book.
Aleja la placa lógica ligeramente de la cámara trasera.
No intentes remover la placa lógica todavía ya que está aun conectada por un cable de antena en la parte trasera.
Voltea la placa lógica hacia la batería como si estuvieras volteando la página de un libro.
