Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Traduciendo paso 2
Paso 2
Use a spudger (or your fingernails) to remove the gold antenna. The antenna bends easily, so make sure not to apply too much pressure. When re-assembling, put the gold antenna in place before inserting the antenna circuit boards.
Use the spudger to remove the connector on the left side.
Remove the 2.4 mm Phillips screw.
Remove the 1.6 mm Philips screw.
[* black] Use a spudger (or your fingernails) to remove the gold antenna. The antenna bends easily, so make sure not to apply too much pressure. When re-assembling, put the gold antenna in place before inserting the antenna circuit boards. | |
[* black] Use the spudger to remove the connector on the left side. | |
- | [* red] Remove two Phillips screws. |
+ | [* red] Remove the 2.4 mm Phillips screw. |
+ | [* yellow] Remove the 1.6 mm Philips screw. |
