Saltar al contenido principal
MacBook Pro 13" Unibody Mid 2009 Upper Case Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 7
MacBook Pro 13" Unibody Mid 2009 Upper Case Replacement: paso 0, imagen 1 de 1
  • While continually trying to click your trackpad, gently tighten the T6 Torx set screw until the clicks return to their factory "feel."
  • You can tell when the screw is tightened just right by the noise it makes when the trackpad clicks. If the set screw is too loose, the trackpad will have excessive play before it clicks. If it is too tight, the trackpad will click too easily and won't make the characteristic loud mouse clicking noise.
Insertar traducción aquí
