Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Paso 7
Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total). Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8.
  • Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total).
  • Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8.
Retire los dos tornillos Torx externos de 6,5 mm que sujetan cada uno de los dos soportes de pantalla a la caja superior (4 tornillos en total).
[* red] RemoveUse your Torx driver to remove the two outer 6.5 mm Torx screws securing each of the two display brackets to the upper case (4 screws total).
[* icon_note] Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8.
