Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Paso 2
Disconnect the camera cable by sliding it horizontally out of its socket. Pull the cable parallel to the surface of the logic board, in the direction of the optical drive. Do not pull straight up, or you will destroy the connector.
  • Disconnect the camera cable by sliding it horizontally out of its socket.
  • Pull the cable parallel to the surface of the logic board, in the direction of the optical drive. Do not pull straight up, or you will destroy the connector.
  • If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
  • If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
Desconecte el cable de la cámara retirando el extremo macho directamente desde su socket.
Hay un pequeño pedazo de plástico duro pegado a la tabla lógica que para el cable de la cámara de caerse de su zócalo. Asegúrese de pelar esto primero o podría dañar los conectores.
Asegúrese de halar el conector paralela a la cara de la tabla lógica y hacia la unidad óptica, no directamente desde su zócalo.
[* black] Disconnect the camera cable by pulling the male end straight away fromsliding it horizontally out of its socket.
[* icon_caution] There is a small piecePull the cable parallel to the surface of hardthe logic board, in the direction of the optical drive. Do '''not''' pull straight up, or you will destroy the connector.
[* black] If you see a [https://d3nevzfk7ii3be.cloudfront.net/igi/FdbjNAIY4CP3TQZk.full|small
plastic retainer|new_window=true] stuck to the logic board that stopsprevents the camera cable from falling out of its socket. Be sure tosliding out, peel this off first or you could damageit up carefully from the connectors.
[* icon_note] Make sure
logic board. Apply a little heat from a hair dryer or heat gun if necessary to pullhelp soften the connector paralleladhesive holding it in place. '''Do not''' attempt to forcibly disconnect the facecable with the retainer in place.
[* black] If you still have trouble, use the point of a spudger to push at each side
of the logic boardconnector and toward the optical drive, not straight up[guide|25629|"walk" it slowly from its socketsocket|stepid=64975].
