Saltar al contenido principal
MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 15 guías que incluyen este paso.
Inglés
Holandés
Paso 4
MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: paso 0, imagen 1 de 2 MacBook Pro 15" Unibody Early 2011 Optical Drive Replacement: paso 0, imagen 2 de 2
  • Remove following two screws:
  • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
  • One 8.6 mm Phillips screw
  • One 3.9 mm Phillips screw
  • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
Insertar traducción aquí
