Saltar al contenido principal
Canon PowerShot G1 X Mark II Motherboard Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 22
Canon PowerShot G1 X Mark II Motherboard Replacement: paso 0, imagen 1 de 3 Canon PowerShot G1 X Mark II Motherboard Replacement: paso 0, imagen 2 de 3 Canon PowerShot G1 X Mark II Motherboard Replacement: paso 0, imagen 3 de 3
  • Use the plastic spudger to remove the ribbon cable from the motherboard by placing the spudger under the ribbon cable connector and pulling up.
  • Remove the 2.8mm screw from the motherboard.
  • Do not try to remove the motherboard from the camera yet.
  • Carefully rotate the motherboard upward.
  • Use the plastic spudger to remove the ribbon cable from the bottom of the motherboard by placing the spudger under the ribbon cable connector and pulling up.
Insertar traducción aquí
