Saltar al contenido principal
Canon PowerShot G16 Motherboard Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 13
Canon PowerShot G16 Motherboard Replacement: paso 0, imagen 1 de 3 Canon PowerShot G16 Motherboard Replacement: paso 0, imagen 2 de 3 Canon PowerShot G16 Motherboard Replacement: paso 0, imagen 3 de 3
  • Open the two ZIF connectors by flipping them up using a plastic opening tool on the motherboard.
  • Make sure to pull the cable ribbon straight out and not up because pulling it up may harm the connector.
  • Be careful not to pinch the cable while pulling it out because it can easily be damaged if pinched. It is helpful to pull it out by the tabs that are built into the connector ribbon.
  • Disconnect the two cable ribbons by pulling them straight out.
Insertar traducción aquí
