Saltar al contenido principal
Canon PowerShot G16 Motherboard Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 8
Canon PowerShot G16 Motherboard Replacement: paso 0, imagen 1 de 1
  • Reorient the camera so that you are looking at the side with the black felt circle.
  • Use caution around this black felt covered circle that is right below the screw to be removed. This is the speaker and can easily be damaged if pressed too hard or poked with a screwdriver.
  • Remove the 2.8 mm screw from the right side of the camera if you are looking at the front lens using a Phillips #00 screwdriver.
Insertar traducción aquí
