Saltar al contenido principal
Sustitución de la unidad óptica del MacBook Core 2 Duo
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 22 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 11
Paso 11
MacBook Core 2 Duo Optical Drive Replacement: paso 0, imagen 1 de 1
  • Lift the side of the optical drive closest to you, then slide the drive towards you, and up and out of the computer.
  • Follow these steps to reinstall the optical drive:
  • First, slide its side nearest to the rear of the Macbook under the edge of the rear frame to the left of the hinge, while also sliding the optical drive's mounting tab at its upper left corner under the cables at this location.
  • Lower the drive partially into the lower housing. Keep the hard drive cable away from the optical drive bay.
  • Before dropping the drive fully in place, use a spudger to push forward (towards the front of the drive) on the screw hole in the drive's mounting tab.
  • Push forward the slider, which runs along the far side of the drive, to insert the end of this slider into a small channel in the lower case's frame. This helps hold the drive in place.
  • When you push the slider forward, if the screw hole in the drive's mounting tab doesn't line up over its threaded brass insert in the lower case, the front end of the slider hasn't fully inserted into its channel in the frame. Keep trying, but if the slider won't move further to the right, remove the drive to see if the end of the slider is bent.
  • If the front end of the slider isn't bent, it may be slightly too long. Use a pair of fine cutters to clip off the narrower portion of the end of the slider. The optical drive will still remain firmly in place.
Levanta el lado de la unidad óptica más cercano a usted y, a continuación, desliza la unidad hacia usted, hacia arriba y fuera del ordenador.
Sigue estos pasos para reinstalar la unidad óptica:
En primer lugar, desliza su lado más cercano a la parte posterior del Macbook por debajo del borde del marco posterior a la izquierda de la bisagra, mientras desliza también la pestaña de montaje de la unidad óptica en su esquina superior izquierda por debajo de los cables en esta ubicación.
Baja la unidad parcialmente hasta el alojamiento inferior. Manten el cable del disco duro alejado de la bahía de la unidad óptica.
Antes de colocar la unidad por completo en su sitio, utiliza un destornillador para empujar hacia delante (hacia la parte delantera de la unidad) el orificio del tornillo de la lengüeta de montaje de la unidad.
Empuja hacia adelante el deslizador, que se extiende a lo largo del lado más alejado de la unidad, para insertar el extremo de este deslizador en un pequeño canal del marco de la carcasa inferior. Esto ayuda a mantener la unidad en su lugar.
Cuando empujes el deslizador hacia adelante, si el orificio del tornillo en la lengüeta de montaje de la unidad no se alinea sobre su inserto de latón roscado en la carcasa inferior, el extremo delantero del deslizador no se ha insertado completamente en su canal en el marco.
Si el deslizador no se mueve más a la derecha, retire la unidad para ver si el extremo del deslizador está doblado. Si el extremo delantero de la corredera no está doblado, es posible que sea demasiado largo. Utilice un alicate fino para cortar la parte más estrecha del extremo del deslizador. La unidad óptica seguirá firmemente en su sitio.
