Saltar al contenido principal
MacBook Core 2 Duo Optical Drive Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 22 guías que incluyen este paso.
Inglés
Holandés
Paso 8
MacBook Core 2 Duo Optical Drive Replacement: paso 0, imagen 1 de 1
  • Remove the 2 mm Phillips #00 screw securing the rear corner of the optical drive.
  • When reinstalling this screw, make sure none of the cables nearby get caught under the screw's head.
  • The silver-jacketed Bluetooth cable may be covering the screw. If so, carefully push it aside. You may need to remove the screw holding the ground shield lugs for the two nearby cables before you can move the Bluetooth cable aside sufficiently. This screw is 7mm in earlier models, and may be 4.2mm in Santa Rosa/Penryn and 2009 models.
Insertar traducción aquí
