Saltar al contenido principal
Reemplazo del lente de la GoPro Hero4 Silver
Inglés
Español
Traduciendo paso 1
Paso 1
GoPro Hero4 Silver Lens Replacement: paso 0, imagen 1 de 2 GoPro Hero4 Silver Lens Replacement: paso 0, imagen 2 de 2
  • Use a pair of tweezers to disconnect the ribbon cable from the ZIF connector by flipping up the black retaining flap. You should then be able to pull the cable free.
  • Once the ribbon cable is disconnected, you can remove the black plastic bracket which holds the camera lens.
  • Be careful removing the ribbon cable. It is very fragile and can tear.
Utilice unas pinzas para desconectar el cable tipo cinta del conector ZIF, al mover hacia arriba la aleta negra de retención. Luego deberías poder tirar del cable gratis.
Una vez que el cable tipo cinta esté desconectado, puede quitar el soporte de plástico negro que sujeta el lente de la cámara.
Tenga cuidado al quitar el cable tipo cinta. Es muy frágil y puede romperse.
-[* red] Use a pair of tweezers to disconnect the ribbon cable from the [guide|25629|ZIF connector|stepid=64969|new_window=true] by flipping up the black retaining flap. You should then be able to pull the cable free.
+[* red] Use a pair of [product|IF145-020|tweezers] to disconnect the ribbon cable from the [guide|25629|ZIF connector|stepid=64969|new_window=true] by flipping up the black retaining flap. You should then be able to pull the cable free.
[* black] Once the ribbon cable is disconnected, you can remove the black plastic bracket which holds the camera lens.
[* icon_caution] Be careful removing the ribbon cable. It is very fragile and can tear.
