Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Traduciendo paso 2
Paso 2
Locate the copper-colored ribbon cables connecting the Hero Port to the motherboard.
To remove the connector, use tweezers or a spudger, pry up each side of the connector. Then, lift the connector straight up from it's socket.
[* red] Locate the copper-colored ribbon cables connecting the Hero Port to the motherboard. | |
- | [* black] To remove the connector, use tweezers or a spudger, pry up each side of the connector. Then, lift the connector straight up from it's socket. |
+ | [* black] To remove the connector, use [product|IF145-020|tweezers] or a spudger, pry up each side of the connector. Then, lift the connector straight up from it's socket. |
[* icon_note] When reassembling this piece, do not use too much force to put the black rectangular pins back onto the motherboard. When done right, there will be a 'click'. |
