Saltar al contenido principal
iPhone 4 Verizon Dock Connector Cable Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 11 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
iPhone 4 Verizon Dock Connector Cable Replacement: paso 0, imagen 1 de 2 iPhone 4 Verizon Dock Connector Cable Replacement: paso 0, imagen 2 de 2
  • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
  • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
Insertar traducción aquí
