Saltar al contenido principal
How to Remove a Car Stereo in a Chevy Tracker
Inglés
Español
Traduciendo paso 1
Paso 1
How to Remove a Car Stereo in a Chevy Tracker: paso 0, imagen 1 de 2 How to Remove a Car Stereo in a Chevy Tracker: paso 0, imagen 2 de 2
  • First, you must disconnect the negative end of the car battery.
  • You will potentially be shocked if you mishandle the battery. Make sure the car is off before inspecting the engine and grabbing the negative connector.
  • Open the hood of your car and locate the battery.
  • Look for the negative end of your battery. It is usually indicated with a minus sign next to it.
  • Disconnecting the negative connection prevents you from receiving any electrical shocks while removing the stereo.
Insertar traducción aquí
