Saltar al contenido principal
2003-2007 Honda Accord Battery Replacement
Inglés
Español
Paso 2
2003-2007 Honda Accord Battery Replacement: paso 0, imagen 1 de 3 2003-2007 Honda Accord Battery Replacement: paso 0, imagen 2 de 3 2003-2007 Honda Accord Battery Replacement: paso 0, imagen 3 de 3
  • You will lose your radio station presets and clock time if you do not use a Memory Saver. One will NOT be used in this guide.
  • The battery is located on the front driver's side of the vehicle.
  • Begin using your ratchet to loosen and remove the negative (black) cable from the terminal.
  • You can use a rag or towel to cover the cable in order to prevent a short.
Insertar traducción aquí
