Saltar al contenido principal
iPhone 4 Verizon Speaker Enclosure Assembly Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 8
Paso 8
iPhone 4 Verizon Speaker Enclosure Assembly Replacement: paso 0, imagen 1 de 3 iPhone 4 Verizon Speaker Enclosure Assembly Replacement: paso 0, imagen 2 de 3 iPhone 4 Verizon Speaker Enclosure Assembly Replacement: paso 0, imagen 3 de 3
  • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
  • Remove the speaker enclosure assembly.
  • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
  • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Insertar traducción aquí
