Saltar al contenido principal
Canon PowerShot S400 Battery Replacement
Inglés
Holandés
Paso 6
Canon PowerShot S400 Battery Replacement: paso 0, imagen 1 de 3 Canon PowerShot S400 Battery Replacement: paso 0, imagen 2 de 3 Canon PowerShot S400 Battery Replacement: paso 0, imagen 3 de 3
  • Do not completely lift the circuit board off the camera. The circuit board is attached to the top of the camera by a soldered ribbon cable. Lifting the main circuit board off the camera will break these soldering points.
  • Gently lift the bottom of the main circuit board, the side without the soldered attachment points, like a hinge.
  • Locate the white ribbon cable attached to the underside of the main circuit board.
  • Gently remove the white ribbon cable from the connector.
Insertar traducción aquí
