Saltar al contenido principal
MacBook Core Duo Front Display Bezel Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 21 guías que incluyen este paso.
Inglés
Español
Paso 5
MacBook Core Duo Front Display Bezel Replacement: paso 0, imagen 1 de 2 MacBook Core Duo Front Display Bezel Replacement: paso 0, imagen 2 de 2
  • Sometimes when removing the front display bezel, the retaining clips that should remain captive in the LCD brackets come out with the front display bezel. Follow this and the next step to transfer the clips back to the LCD bracket.
  • Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel. A 0.8mm flat screwdriver may be useful for this step. You may find that it's easier to remove some of these clips by prying up on their long sides.
  • Be careful, as the clips are made of thin plastic and are inherently delicate.
Insertar traducción aquí
