Saltar al contenido principal
MacBook Core Duo Front Display Bezel Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 21 guías que incluyen este paso.
Inglés
Español
Paso 4
MacBook Core Duo Front Display Bezel Replacement: paso 0, imagen 1 de 2 MacBook Core Duo Front Display Bezel Replacement: paso 0, imagen 2 de 2
  • Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
  • Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
  • After freeing all holding tabs, lift the front display bezel away from the display assembly.
  • When reinstalling the front display bezel onto the display housing, you may find it easier to get the tabs and clips to connect if you push on the four sides of the bezel in this order: top, bottom, then the sides (left or right). You may have to apply extra pressure along the bottom side of the bezel to get it to snap into place firmly.
Insertar traducción aquí
