Saltar al contenido principal
Canon Powershot SD880 Back Cover Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Canon Powershot SD880 Back Cover Replacement: paso 0, imagen 1 de 3 Canon Powershot SD880 Back Cover Replacement: paso 0, imagen 2 de 3 Canon Powershot SD880 Back Cover Replacement: paso 0, imagen 3 de 3
  • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
  • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
  • One screw will be located under the rubber USB flap.
  • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
  • Slowly pull the back cover off of the camera.
Insertar traducción aquí
