Saltar al contenido principal
Retina MacBook 2015 Opening Lower Case Assembly
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Inglés
Holandés
Paso 5
Retina MacBook 2015 Opening Lower Case Assembly: paso 0, imagen 1 de 3 Retina MacBook 2015 Opening Lower Case Assembly: paso 0, imagen 2 de 3 Retina MacBook 2015 Opening Lower Case Assembly: paso 0, imagen 3 de 3
  • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
  • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
  • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
  • This step ensures the MacBook is fully powered down and safe to work on.
Insertar traducción aquí
