Saltar al contenido principal
Rubbermaid Reveal Spray Mop Pump Repair
Inglés
Español
Paso 5
Rubbermaid Reveal Spray Mop Pump Repair, Fixing The Pump Plunger (Piston): paso 0, imagen 1 de 2 Rubbermaid Reveal Spray Mop Pump Repair, Fixing The Pump Plunger (Piston): paso 0, imagen 2 de 2
  • The problem is that the plastic pump plunger/piston sticks in the cylinder. Use 120 grit sandpaper and EVENLY sand the circumference of the plunger head and the 2 ribs below it. Test. Repeat until there is better movement but NO loss of suction.
  • Photo 2 shows the plunger/piston sanded so it works nicely in the cylinder without having taken off too much material - you do not want to take off too much. It doesn't need to be super pretty smooth but sanding too rough and uneven will not keep suction. Sand a little at a time and test it at each and every attempt.
  • When you are satisfied put a small amount of petrolium jelly (Vaseline) around the plunger/pistons head and ribs.
Insertar traducción aquí
