Saltar al contenido principal
Rubbermaid Reveal Spray Mop Pump Repair
Inglés
Español
Paso 3
Rubbermaid Reveal Spray Mop Pump Repair, Remove Screws and Separate Pump Body: paso 0, imagen 1 de 1
  • Once the screws are removed the pump body can be split open. Use a metal spudger or a thin flat head screw driver and do this slowly - do not just bust it open as you may damage parts.
  • Pay close attention to the inside parts. You will need to wiggle down the spray pump nozzle casing sleeve (red) that also acts to hold the 2 pump body panels in place.
  • NOTE! You do not need to separate the pump case all the way down to the bottom where the stem meets the red swivel for the mop head. The screw here needs to be losened off enough for you to be able to separate the main body above it.
Insertar traducción aquí
