Saltar al contenido principal
Dell Latitude E6500 Teardown
Inglés
Holandés
Traduciendo paso 18
Paso 18
Dell Latitude E6500 Teardown: paso 0, imagen 1 de 3 Dell Latitude E6500 Teardown: paso 0, imagen 2 de 3 Dell Latitude E6500 Teardown: paso 0, imagen 3 de 3
  • Removing motherboard from bottom assembly. I show a picture of the top palm assembly for precaution again.
  • Disconnect the two ribbon cables found on opposite corners of the motherboard.
  • The cable on the bottom left should have two pressure pins, if not just pull the cable out.
  • The cable on the top right will have two pressure pins for locking, release them and pull the cable out using the hard film.
  • Remove 8 screws from the motherboard using the #0 Philips Screwdriver.
  • 4 black screws are found along the edges of the motherboard.
  • 2 Metalic screws are found underneath the ribbon cable on the bottom left. Remove them. The last 2 screws are on the hard drive cage on the bottom right.
  • Enjoy the sight. You are done! There are a few other parts but those should be easy to remove from here.
Insertar traducción aquí
