Saltar al contenido principal
Dell Latitude E6500 Teardown
Inglés
Holandés
Paso 11
Dell Latitude E6500 Teardown: paso 0, imagen 1 de 3 Dell Latitude E6500 Teardown: paso 0, imagen 2 de 3 Dell Latitude E6500 Teardown: paso 0, imagen 3 de 3
  • Removing the hinge covers, and separating the LCD assembly from the assembly. Part 1 of 2.
  • Locate all antenna cables, and display cables associated from with the LCD assembly.
  • Disconnect all antenna cables, and display cables and loosen them from their routing holders found on the assembly. One antenna is found on the top right corner below the right hinge cover.
  • Remove four screws using a #0 Philips Screwdriver. Two are found in the picture, another two are found on the back.
  • Remove the hinge covers by pushing outwards away from the laptop. Lift and remove.
  • With the hinge covers removed, you will see two screws, one for each of the hinges. Remove these screws with a #0 Philips Screwdriver.
Insertar traducción aquí
