Saltar al contenido principal
Sony Cyber-shot DSC-W290 Flash Bulb Assembly Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Sony Cyber-shot DSC-W290 Flash Bulb Assembly Replacement: paso 0, imagen 1 de 3 Sony Cyber-shot DSC-W290 Flash Bulb Assembly Replacement: paso 0, imagen 2 de 3 Sony Cyber-shot DSC-W290 Flash Bulb Assembly Replacement: paso 0, imagen 3 de 3
  • Tilt top casing up and towards you.
  • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
  • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
Insertar traducción aquí
