Saltar al contenido principal
Canon PowerShot SD800 IS Flash Assembly Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Traduciendo paso 3
Paso 3
Canon PowerShot SD800 IS Flash Assembly Replacement: paso 0, imagen 1 de 1
  • Gently pull the red and black wires, lifting the white connector upwards, out of its position. (You may need to jiggle the wires from side to side somewhat to loosen the connector.)
  • Now that all cables and screws are disconnected, you can now remove the flash assembly.
  • To reinsert, line up connector with the copper leads on the camera, and gently press the white piece into place.
  • The black cable should be closer to the top of the camera.
Insertar traducción aquí
