Saltar al contenido principal
Canon PowerShot SD800 IS Flash Assembly Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Canon PowerShot SD800 IS Flash Assembly Replacement: paso 0, imagen 1 de 1
  • Remove one 3.9mm screw from inner frame.
  • NEW: Steps 8–11 (Removing the LCD Assembly) are unnecessary and can be skipped!!! Instead of the step shown here, you may access the Flash Assembly from the side of the camera—unscrewing it from the metal bracket that is attached to the inner frame. (The bracket will be clearly visible after removing the back and front covers—sorry, no photo!) Note that the Flash Assembly is also held to the bracket by 2 small posts along its plastic body; after unscrewing, pull the assembly gently away from the bracket to unseat the posts.
Insertar traducción aquí
