Saltar al contenido principal
How to Fix a Cross Threaded or Stripped Hole in Aluminum
Inglés
Español
Traduciendo paso 1
Paso 1
How to Fix a Cross Threaded or Stripped Hole in Aluminum: paso 0, imagen 1 de 1
  • Determine which hole has the cross threaded or stripped screws.
  • Determine the size of the current thread. Threads are called out by the outer diameter, a dash, and then the thread count. For example, the tap shown is 1/4"-20".
  • The hole's outer diameter can be determined by measuring the width of the screw or bolt that goes into the hole.
  • The thread count can be determined by counting the number of threads in one inch of screw length.
  • Select the appropriate tap size.
  • Taps are sharp. Do not handle the teeth.
  • Install the tap into the tap handle (See photo).
Insertar traducción aquí
