Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Traduciendo paso 4
Paso 4
Use the Philips #00 screwdriver to pry open the charging port cover.
Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
Remove both 3.1 mm screws using the Phillips #00 screwdriver.
