Saltar al contenido principal
Canon Powershot A720 IS Lens Replacement
Inglés
Holandés
Paso 6
Canon Powershot A720 IS Lens Replacement: paso 0, imagen 1 de 2 Canon Powershot A720 IS Lens Replacement: paso 0, imagen 2 de 2
  • Carefully lift and turnover the LCD Screen so you are able to see the motherboard.
  • Be very careful with the LCD Screen and avoid wearing a static bracelet as it will cause release of static discharge.
  • Without touching the motherboard, grab the LCD Screen's ribbon wire with your thumb and index finger and carefully disconnect it from the ZIF connector. Have your fingers close to the ZIF connector when pulling the ribbon wire out. The LCD Screen should be positioned in between your fingers.
  • Do not rip the ribbon wire or the red and black power wires when pulling the LCD screen out.
  • You do not have to unsolder the LCD screen if you are only replacing the lens.
Insertar traducción aquí
