Saltar al contenido principal
BlackBerry Tour 9630 Keypad Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 6
BlackBerry Tour 9630 Keypad Replacement: paso 0, imagen 1 de 2 BlackBerry Tour 9630 Keypad Replacement: paso 0, imagen 2 de 2
  • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the black and white coaxial connectors (as close to the head as possible) and lift straight up from the board.
  • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
  • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  • Don't try to force the connector into place or you may permanently damage it.
Insertar traducción aquí
