Saltar al contenido principal
HP EliteBook 8440p LCD Replacement
Inglés
Español
Paso 4
HP EliteBook 8440p LCD Replacement, Separate the back cover from LCD: paso 0, imagen 1 de 3 HP EliteBook 8440p LCD Replacement, Separate the back cover from LCD: paso 0, imagen 2 de 3 HP EliteBook 8440p LCD Replacement, Separate the back cover from LCD: paso 0, imagen 3 de 3
  • Each lower corner of the screen has two PH0 screws. Remove them.
  • Note that the two holes with screws have little triangle marks. This will make your reassembly easier when you try to remember which two holes to use.
  • Lift the screen 45º of the laptop. The back should now be disconnected from the main frame of the display, and should be able to be pulled up to 90º.
Insertar traducción aquí
