Saltar al contenido principal
iPod Touch 4th Generation Front Panel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Holandés
Paso 7
iPod Touch 4th Generation Front Panel Replacement: paso 0, imagen 1 de 3 iPod Touch 4th Generation Front Panel Replacement: paso 0, imagen 2 de 3 iPod Touch 4th Generation Front Panel Replacement: paso 0, imagen 3 de 3
  • Insert the edge of an opening tool under the steel mid plate near the bottom left corner of the Touch.
  • Slowly pry upward to separate the plate from the adhesive securing it to the plastic inner case.
  • If the plate is still attached to the logic board, re-warm the area to loosen the adhesive, then slowly separate the plate from the logic board using the opening tool.
  • There is a thin, fragile ribbon cable underneath the plate. As you pry the plate up, be very careful not to rip the cable.
  • This cable may stick to the plate and will tear very easily if you're not careful. Work slowly and be careful not to strain the cable.
Insertar traducción aquí
