Saltar al contenido principal
Nexus 6 Rear Case Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Nexus 6 Rear Case Replacement: paso 0, imagen 1 de 2 Nexus 6 Rear Case Replacement: paso 0, imagen 2 de 2
  • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
  • Pry open the back casing using the soft plastic opening pick.
  • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
  • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
  • You may need an iOpener to loosen up the adhesive. Check out the Instrucciones de iOpener for info on how to use it.
Insertar traducción aquí
