Saltar al contenido principal
PlayStation Move Teardown
Inglés
Español
Traduciendo paso 13
Paso 13
PlayStation Move Teardown: paso 0, imagen 1 de 2 PlayStation Move Teardown: paso 0, imagen 2 de 2
  • PlayStation Move Repairability: 8 out of 10 (10 is easiest to repair)
  • Good: You can easily open the controller to access the internals.
  • Good: Battery can be easily replaced once you open the controller -- it has a connector instead of soldered contacts.
  • Good: The trigger comes out as one unit, making it easy to replace.
  • Good: The LED has a heatsink that will make it operate more efficiently and last longer.
  • Bad: Other components, such as the vibrator motor and LED, are soldered to the motherboard.
Insertar traducción aquí
