Saltar al contenido principal
Nexus 6 Battery Replacement
Inglés
Español
Traduciendo paso 1
Paso 1
Nexus 6 Battery Replacement, Battery Disassembly: paso 0, imagen 1 de 3 Nexus 6 Battery Replacement, Battery Disassembly: paso 0, imagen 2 de 3 Nexus 6 Battery Replacement, Battery Disassembly: paso 0, imagen 3 de 3
Battery Disassembly
  • With your hands, pull the battery away from the rest of the casing.
  • Using tweezers, unplug the battery connector. Pry up underneath the hard backing plate, taking care to not peel the cable off of the backing plate.
  • Measure the location of the charging coil on the old battery and transfer those measurements to the new battery. Carefully peel off the charging coil.
  • Transfer the charging coil to the new battery. For the four-wire connector on the other side, measure the location of the contacts/pins on the phone itself and transfer it to the backside of the battery.
Insertar traducción aquí
