Saltar al contenido principal
Reemplazo de pantalla LCD de Sony Xperia Compact
Inglés
Español
Paso 4
Sony Xperia Z3 Compact LCD Screen Replacement, Remove the screen: paso 0, imagen 1 de 3 Sony Xperia Z3 Compact LCD Screen Replacement, Remove the screen: paso 0, imagen 2 de 3 Sony Xperia Z3 Compact LCD Screen Replacement, Remove the screen: paso 0, imagen 3 de 3
Remove the screen
  • The steps are same as removing the back cover but a bit more difficult. Heat up for 3 minutes, lift the screen with the suction cup and if necessary, cut through the adhesive.
  • When removing the screen, be careful: the earpiece is stuck to it. Don't lose it.
  • If your screen is cracked or broken, be careful when removing as bits of glass may come off and cut your fingers.
  • Why does the disassembled screen come with the earpiece? The reason is that the earpiece is stuck in place on the touch panel/screen combination directly, rather than kept in a frame on the main flex (like the cameras, for instance).
Los pasos aquí son los mismos que para quitar la parte de atrás, pero con mas dificultad.Calienta por 3 minutos el marco , corta el pegamento y remueve la bocina en la parte de arrbia con cuidado
Por que la pantalla del Sony Xperia Z3 Compact viene con la bocina? La respuesta es por que la bocina esta pegada al digitalizador directamente sin ningún marco.Para evitar dañar la bocina tenemos que ser cuidadosos al quitar el pegamento.Nota la posición en la que se quito la bocina.
-[* black] The steps are same with removing back cover but more difficult. Heat up for 3 minutes, cut the sticker with much more effort and take the screen with earpiece on carefully.
-[* black] But why Sony Xperia Z3 Compact disassembled screen will come with earpiece? The answer is the earpiece is sticking on the touch panel directly with no any frame. So for avoiding damaging the earpiece, we need to be very careful when cut the sticker along the top side. Notice the position and get rid of the earpiece.
+[title] Remove the screen
+[* black] The steps are same as removing the back cover but a bit more difficult. Heat up for 3 minutes, lift the screen with the suction cup and if necessary, cut through the adhesive.
+ [* black] When removing the screen, be careful: the earpiece is stuck to it. Don't lose it.
+ [* black] If your screen is cracked or broken, be careful when removing as bits of glass may come off and cut your fingers.
+[* black] Why does the disassembled screen come with the earpiece? The reason is that the earpiece is stuck in place on the touch panel/screen combination directly, rather than kept in a frame on the main flex (like the cameras, for instance).
