Saltar al contenido principal
iPad Mini 3 Wi-Fi Logic Board Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Paso 32
iPad Mini 3 Wi-Fi Logic Board Replacement: paso 0, imagen 1 de 3 iPad Mini 3 Wi-Fi Logic Board Replacement: paso 0, imagen 2 de 3 iPad Mini 3 Wi-Fi Logic Board Replacement: paso 0, imagen 3 de 3
  • Reinsert the opening pick under the Lightning connector ribbon cable from the case-side edge.
  • Slide the pick along the Lightning connector ribbon cable and under the logic board.
  • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
Insertar traducción aquí
