Saltar al contenido principal
MacBook Pro 17" Unibody Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 30 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
MacBook Pro 17" Unibody Battery Replacement: paso 0, imagen 1 de 3 MacBook Pro 17" Unibody Battery Replacement: paso 0, imagen 2 de 3 MacBook Pro 17" Unibody Battery Replacement: paso 0, imagen 3 de 3
  • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
  • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
  • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
  • Pull the tab parallel to the face of the logic board.
Insertar traducción aquí
