Saltar al contenido principal
CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown
Inglés
Español
Paso 3
CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: paso 0, imagen 1 de 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: paso 0, imagen 2 de 2
  • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
  • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
Insertar traducción aquí
