Saltar al contenido principal
Canon PowerShot A4000 IS Flash Replacement
Inglés
Holandés
Traduciendo paso 1
Paso 1
Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: paso 0, imagen 1 de 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: paso 0, imagen 2 de 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: paso 0, imagen 3 de 3
Removing the Flash
  • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
  • Your flash should come out very easily if you use your spudger to lever it out carefully.
  • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Insertar traducción aquí
