Saltar al contenido principal
Xbox 360 S Top Panel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Inglés
Holandés
Paso 9
Xbox 360 S Top Panel Replacement: paso 0, imagen 1 de 2 Xbox 360 S Top Panel Replacement: paso 0, imagen 2 de 2
  • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
  • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
  • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Insertar traducción aquí
