Saltar al contenido principal
Reemplazo del conjunto de pantalla del iPhone 4
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 9
Paso 9
iPhone 4 Display Assembly Replacement: paso 0, imagen 1 de 3 iPhone 4 Display Assembly Replacement: paso 0, imagen 2 de 3 iPhone 4 Display Assembly Replacement: paso 0, imagen 3 de 3
  • De-route the digitizer and LCD cables through the steel inner frame, and remove the display from the iPhone.
  • When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable.
  • When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
  • If the digitizer cable has not been installed correctly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
  • During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
Desvía los cables del digitalizador y del LCD a través del marco interior de acero y quita la pantalla del iPhone.
Al reinstalar la pantalla, endereza con cuidado los cables de datos del digitalizador y del LCD y pásalos por la ranura cortada en el marco de acero. Esta foto muestra el ensamblaje de la pantalla instalado incorrectamente, con un pliegue en el cable del digitalizador.
Cuando el panel frontal se haya instalado correctamente, los cables del LCD y del digitalizador deben estar inmediatamente uno al lado del otro y deben tener la misma longitud, como se muestra en la segunda foto.
Si el cable del digitalizador no se ha instalado correctamente, no llegará a su zócalo en la placa lógica. No intentes tirar de él a la fuerza, ya que se romperá. Quita el conjunto de la pantalla, endereza el cable e introdúcelo hasta su longitud máxima, como se muestra.
Durante el reensamblaje, no toques el área metálica en la base del cable de datos del LCD, ya que esto puede causar problemas con el LCD. Si lo tocas accidentalmente, límpialo suavemente con una toallita con alcohol antes de continuar.
